I just finished a build, and am having a an issue with a scratchy gain control.
There is no DC on the pot, and I've tried the following with no improvement:
- Changed 12AX7 whose grid is connected to pot
- Changed pot
- Changed ground wire from pot and tried different ground points
- Drastically altered lead dress
- Cleaned flux residue around tube socket
If I disconnect the input lug of the scratchy control there is still scratch with just the ground and wiper connected to the grid. That lead me to believe it was the tube itself or pot, but it's not.
The only thing that makes the noise go away is touching my hand to the chassis while rotating the control. What could this mean?
I thought maybe a grounding issue, but everything checks outs. I only have one ground point at the input jack, and it's a method I use often with no problems.
HELP!
- Changed pot
HELP!
