Hi all, This is my first post so please forgive me if I'm not up to speed with the how to's. I'm having a problem with a SWR 750x where all seems fine except when I put a load on the speaker output. When I do, I can see the current draw on my variac is excessive. There are no symptoms or oscillations from the preamp noticeable on the oscilloscope. I've checked all the devices on the power amp board and no shorts that I can find. Apparently the problem is only once the transistors turn on. Replaced the 2SC3264 power transistors and the drivers. It came in with all 6 of the power transistors shorted and the .5 ohm 5 watt resistor open at the power in jack. At present, I have 2 of the 6 power transistors installed, and a 150 watt bulb in line with the variac. BTW current draw is nearly nill without the load connected. Even the headphone out has an unclipped output as long as the speaker load is not connected. Without the 150 watt bulb in line when I ramp up the variac the current meter will suddenly peg at about 50%. All voltages appear normal
Any suggestions are appreciated. Thanks!
