So I was at my friend's shop and spotted an old Harmony H306. It worked, but sounded real 'old'...basically sounded like it needed new caps and tubes. I picked it up for a great price and left.
Once I opened it up, I noticed it had been worked on (orange drops instead of the wax caps, a couple resistors changed off of the can cap.)
So basically I did the following:
-cleaned all the pots
-added ground plug
-removed the 'death cap' off of the fuse
-switched a few of the Orange Drops to Mallorys (I'm not a OD fan)
-replaced the 25uf/25V electrolytic
-replaced the can cap with a JJ 40/20/20/20 (not using the 40)
-replaced the two 220K resistors coming from the can cap (someone had put random ones in there and had them flying in the air)
Problem: powers on, voltages all seem fine, no sound from any input.
I have a B+ of about 360V w/all tubes installed. The only 'output' I get is the scratchy sound when you test voltages off of the preamp tubes.
Any insight as to what might have happened? Like I said, It was working before.
I do have a stock H305 on hand that I've been using as reference 'if needed'.
Here's a pic 'before':
Here are a few after pics. (I was short a few .02's, waiting for my order):
-added ground plug
