Wondering what would cause this waveform to distort in the manner shown. Only does it when you get into clipping, and the farther into clipping the worse it gets, until the scope cannot even trigger it anymore.
Clipping a .001 cap over one of the plate resistors for V1 or V2 it goes away. Also clipping the scope probe ground to the chassis makes it stabilize. is this a grounding or decoupling scenario? It ONLY does it on the high gain input. On lower gain input you can go into heavy clipping and the signal is stable.
I believe these are the correct shames
pre -- http://www.drtube.com/schematics/marshall/2203prem.gif
power/psu -- http://www.drtube.com/schematics/marshall/2203pwrm.gif
![Click image for larger version
Been referencing these threads. It does not squeal though, this is only visible through a scope
Marshall JMP making squealing noise
http://music-electronics-forum.com/t38879/
