JTM30 has two issues. 1) excessive hum and 2) bias mod problem
Problem 1: The amp powers on but has substantial hum that overrides any amplified audio signal. I can unplug CON3 and that noise is eliminated - of course a slight hum is introduced with CON3 disconnected but that is expected. Neither channel volume effects the hum, but it is eliminated when the MASTER VOLUME is all the way down. Tested IC3 op amp and there is negative DC voltage on every pin.
IC3 LM348N - all voltages DC
pin 1 (-4.7) ... pin 8 (-16.5)
pin 2 (-5.0) ... pin 9 (-15.4)
pin 3 (-5.6) ... pin 10 (-14.6)
pin 4 (-5.9) ... pin 11 (-14.7)
pin 5 (-7.4) ... pin 12 (-12.4)
pin 6 (-8.5) ... pin 13 (-11.5)
pin 7 (-9.5) ... pin 14 (-10.3)
Problem 2: The power tubes are redplating and bias idle current is excessive. The bias circuit was previously modded - the zener string (ZD101, ZD102, and ZD103) was removed in favor of a 56K R - 50K pot - 56K R string. I'm not able to adjust the bias with the bias pot. I have confirmed that both 56K resistors are good and the pot itself works fine in isolation. The stock JTM 30 has a zener diode regulated bias supply that is "non adjustable", so it runs hot because Marshall calls it a "class A amplifier" with two 5881s producing ~30 watts. This amp still has what appears to be the stock power tubes.
I've done this mod myself to a couple of these in the past and have had no problems, but I had taken working amps and performed the mods entirely myself from start to finish.
Can these two problems be related?
Is that LM348N op amp toast?
