You need a solution, but we are going by your recollection as there is no documentation of your previous mod.
I'm aboard with what you think you did before except for you leaving R132 alone. Your new circuit in parallel with R132 immediately drops the bias voltage and makes the tubes run hotter, near as I can tell.
But what you are trying to accomplish is to make them run cooler than the stock "class A", correct?
I'm going to guess that when you did the mod before you removed R132 and suggest you try it.
