tiny terror tranny?
  • tiny terror tranny?
    hey guys , does anyone here have a spec sheet for the tiny terror tranny's? power tranny has a brown,purple,black,red,yellow,and blue, primarys? purple orange,green,yellow,yellow,secondary?
    the output has primary-red,brown(ct?) black. secondary-yellow,orange, black?
    chuck.
    hey guys i have found the wiring order of both trannys. there is a green-ov on the secondary of the power tranny and i was wondering where this wire connects, to the ground of the rectifier? i had the green 0v wire on the secondary of the power transformer wired to ground but when i ground my rectifier the amp blows the fuse. when i disconnect one of the grounds the amp stays on but no sound?
    Chuck.
      The '-' lead on the rectifier bridge should go to ground, the 'hot' (whichever voltage) goes to one '~' lead and the green wire goes to the other '~' lead. None of the HV secondary wires should be grounded.
        sch, which may help (not sure how correct it is)
        The sch shows the HV secondary connection, none of which are grounded, as mhuss correctly stated
