Hi all,
I am repairing this Bassman 1200 (same amp as the Sunn 1200S) with a faulty ouptu stage.
Without a load, the amp has a clean signal on its output (no apparent distortion and with proper swing), but with a load connected to it, there is almost no output (0.1v peak to peak max). The output is at 0V in both cases so it seems that the O/P transistors are ok. The dual rail supplies read fine too. I can't see any blown active part and I have resoldered all of the transistors located on the smaller heatsink (because that is often a source of problems on this amp)
Any ideas? (schematic attached)
