Ok guys, I got roped into trying to deal with this issue after another tech gave up on it, and I don't know the whole history. And Second, I'm not an Amp tech. I am an EE with 20+ years in electronics and medical instrument service, mostly dealing with Diagnostic Ultrasound systems. Don't exactly see many tubes in those anymore. But I'm doing the best I can with this one.
I was told that "it blows fuses after a while" probably referring to the t500ma HT fuse, but not sure of that. It came to me minus the cap to the bayonet fuse holder, so rather than replacing the soldered on board unit, I used a cooper bulkhead mount and soldered in some leads to the board with spade connectors. Easier to put an ammeter in series with, and the added bonus of not breaking off the board if somebody drops an fx rack on it or something like that. That was the easy part.
Hooked the speakers up, put in the correct fuse, turned down the master volume and was letting it warm up to check the bias, when I noticed some smoke trying to sneak out of the base of the v3 socket on the preamp board! Shut everything back down, checked fuses, pulled the power tubes and tried one more time. Definitely getting hot on pins 4-5 and 9 of v3, with maybe a little extra current getting pulled through pin 9 of v4 as well. Let it bleed down, pulled the 12ax7's out and measured pin 4 to 5. v 1, 2, and 4 read 33 to 37 ohms, V3 read 11. New tube on order. Got that far OK.
So, after I get the new v3 installed, and make sure the bias on the kt88's is between 43 and 48mv, and nothing else is trying to smoke, what else should I check before I turn the volume up a little and see how she runs? Current through FS2 seems like a good thing to watch. Anything else? If all looks good, plug in and run it for a while, then recheck bias? What else?
Thanks for the responses
James in Houston
James in Houston
