hi all,
have a fender twin reverb that i have been asked to repair when i look inside i find that it a has two 6l6gc tubes in v7 and v10 and two 5881 tubes in v8 and v9 and i ask how can this work properly as i understand they have different bias setting and different power outputs, the grid resistor 1.5k on v9 is a piece of carbon now and v10 screen grid resistor 470ohm is open, the amp went dead by the look of things when brown wires to the output transformer rubbed through on the 470ohm resistor the resultant flash bang killed the amp for now.
the twins that i have worked on before had elther a set of 6l6gc or a set of 5881, so my question has anyone seen an amp with this setup before and if so how does it work?
i have been trying to date the amp but no tube layout card in the cab the number stamped on the chassis f115345 which i think puts it 1981 the eia numbers on the output tr is 606 125 and on the mains tr is 606 044, if that helps.
the owner bought this as a fully serviced vintage twin, it has none matching speakers fitted as well but i have seen that before
thanks any help will be appreciated.
