Hi you all,
I am having trouble finding the issue on this mesa nomad 55 amp.
The amp functions all well, but it makes a lot of noise (or hiss) on all 3 channels.
The power tubes have recently been replaced and are OK.
The first 12AX7 is a bit microphonic so I changed that one without result.
There's also quiet a bit of hum which increases turning up the volume.
With all the controls on 5 its really very noisy without any imput.
The ground on the imput jack functions well.
When I pull the V4 or the V5 the amp is quiet so the power stage must be OK.....?
On the PCB there are 2 large filter capacitors (220uF/300V) which date 0024 so they are 15 years old.
This might be the cause of the hum but can it also cause the noise?
The PCB is dated 1999.
I've checked the capacitors by measuring the voltage directly after switching off and within 20 seconds the voltage drops from 300 to zero.
I hope any of you have any experience on this amp and had the same problem.
I also cleaned all the pots and contacts with no result.......
Any help or suggestions are welcome
I will attach the schematic below.....
Thanks in advance!
Peter
Thanks in advance!
Peter
