Hi- Ive got a simple resisitor to replace, due to someone poking around & stupidly shorting x to y whilst trying to be helpful and giving my amp a quick check/ voltage & tubes bill of health (which was kind, and a pro he is.. but rather unbelievable! I thought you took in a broken amp > fixed amp comes out.. not ok amp in > broken amp comes out!).
The tubes started red-plating & soon discovered after much head scratching, that the bias circuit (my hunch) was cause s'how. Sure enuff yes I do we found the metal film resistor R69 in the bias circuit was blown & reading open (but no physical sign of burnt as its a "fuse" type of thing.. right?). There is no evidence at all that anything was responsible -other- than poking around, taking CP1 and CP2 off and mixing up putting back on again & not noting which way around (confusing both of us) & a shorting due simply to this. It happened immediatly after poking the CP1/ CP2 areas, & little else was poked at all so 99.8& likely a short occured here IMO.. besides, the adjacent cap to R69 was wiggled: fine, tubes checked: fine, any wires or preamp areas: fine so no sign of any cap, wire short in situ, preamp component etc etc was to blame.
Its R69 on the 1st google result here, a pdf which alas I cant link directly to it seems apologies (but once on the pdf, its pg 6 for the schematic, pg3/ last down is exact description of R69).
https://www.google.co.uk/search?q=54...Vv9og4Zo8ouPQA
Can someone help me find a repalcement? Im confused over this "fuse" description added to it/ never heard of such a resisitor.
Thanks SC
Thanks SC
