I recently repaired an Ace Tone Bass-6 head for someone, but being more of a tube amp tech than a SS amp tech, I'm not actually sure why my fix worked.
No one seems to have a schematic for this Ace Tone amp, which appeared maybe around 1970, but the output stage is very similar to the Peterson/80W Rhodes amp modules, a fairly standard transformer-coupled SS output stage from this era. Both are rated 40 Watts. The Ace Tone uses Sanken silicon transistors instead of germanium.
The Ace Tone was stable into some speakers, like a generic 12" salvaged from some organ, and was perfectly stable into a resistive dummy load, but would immediately start motorboating at turn-on into other speakers, particularly a JBL E120. On advice from other techs, I checked all the PS filter capacitors both with an ESR meter and by clipping in larger capacitors to swamp any problems, but none of that had any effect on the LF motorboating/oscillation. Then, I remembered the Rhodes schematic and the fact that it includes a 270 Ohm 2W resistor between the output and ground. The Ace Tone had no such resistor. As a last-ditch attempt at a fix, I clipped in a 100 Ohm resistor. The motorboating immediately stopped.
One possibly significant detail is the fact that someone replaced the output jack on the Ace Tone at some point, so it's conceivable that this amp might have had such a resistor mounted on the original output jack, but without a schematic, there's no way to know.
I understand that placing a resistor in parallel with the L and/or C of the speaker load makes the load look flatter to the output stage, but for the sake of my own education, I'd like to know more about why this resistor is necessary and why my fix worked.
I'm attaching a copy of the Rhodes schematic for convenience and a photo of the inside of the Ace Tone Bass-6.
