Good Morning all
Ive had a TSL100 for a service, Blown pair of Tubes, Replaced and re biased all seems ok, Then i noticed some bias drift.
Decided to to the mod where you cut around pin 5 and wire resistors in directly to the tube base etc
See below
The Marshall TSL122 TSL100 thermal bias drift repair page did all this ,as ive done below with working results
TSL100___TSL122_Valve_PCB__60_.pdf
After about 20 mins again started to drift, stuck two DMM on and watched to see what is drifting. ( without tubes )
V5-6 drifting V7-8 are stable
So i changed all components in the bias circuit trim pots and all resistors and caps
Still the same. Used the heat gun and freezer spray found by spraying around the PI tube area voltage would drop
Changed the 82k 100k and 2 x 680K both 22nf, Removed the PI tube voltage stable, Swapped the tube still drifting
Is there any other known issues with the board conductivity
any help would gratfull, I know about the replacement board, but at this present time i need to repair if possible
BBB
See below
BBB
