I can't find a schematic for this amp. I'll have to wait until tomorrow to contact Peavey.
My problem is related to the +15 supply.
Without plugging in the preamp board- the supplies sit right at ~ +15 -15.
Plugging in the preamp board with the TL074s and 4558s removed- the supplies are still fine.
If I add the chips to the board, the -15 rail is fine, but the +15 rail will begin to sag lower and
lower. It will fluctuate 8+ to 12+ and then sink to 4+ and then even go negative to -8 or so.
I inserted two new TL074s, alone, and that was enough to cause the issue.
I have replaced the caps on the low voltage supplies, replaced a couple
bad looking resistors, and replaced the 2.2 electros on the preamp board.
Again- unloaded it's fine, as soon as you add a couple chips....
What else could I look for?
