Picked up an 8080 for my next project. Issue was no sound.
Using a 440 hz signal, I traced the issue to the effects loop. Signal stopped between IC5 and IC6. I placed a jumper cable in the effects send/return jacks. Now I had
a signal all the way to C17.
I placed the chassis back into the amp. Hooked up the speaker and reverb tank. With jumper cable in effects loop...
Issues are;
Clean channel, when strumming it sounds like the speaker is rattling like crazy, harder the strum, the worse the rattle.
Gain channel, hardly any sound at all, occasionally there is sound with rattle.
All pots, switches, jacks have been cleaned.
Every IC I tested had +15 VDC at pin 8 and -15 VDC at pin 4. However I did not test every IC.
12ax7 had 199 VDC at plate fed from R110 and 115 VDC at other plate fed by R109.
Other tests;
Using another amps pre-amp signal fed into the 8080 return jack, the 8080 sounds fine, the speaker sounds fine with no rattles.
Using the 8080 as a pre-amp to another amp, all I get is a loud ground hum in the other amp. I hear no guitar signal.
Could all these issues be related to the effect loop problem?
Are there other components that could be at fault?
Thank you in advance! Mark
Issues are;
Other tests;
