Ampeg BA115 Transistor Replacement?
Yeah I double that one... Be very careful pulling those off while they are still soldered onto the PCB. Actually unsolder each one and attempt to remove them first to be even safer. My thinking is the heat sinks slip on easier in one direction and almost lock up the other way. So remove them then by pushing from the bottom of the transistor(where the pins are) so that the top pushes outward from the heat sink and see if that is any easier.When the going gets weird... The weird turn pro!
