Hello All, I have a 67 Bassman head that I converted to blackface specs. That is,
1) I rewired the PI to blackface specs (followed the AA864 schematic),
2) I converted the bias to an adjustable bias,
3) Replaced the electrolytic cap in the power section with F+T,
4) Replaced the 100k bias feed resistors at the output tubes with 220k,
5) Swapped out the tone caps in the Bass channel with .02uf orange drops, also swapped the 100k for a 56k slope resistor and took out the deep switch cap.
6) got rid of the 220k suppressor caps coming of the plates of the output tubes.
After all these mods I find that the amp has an early break up which I would like to fix. Now the amp did come with cathode bais in the output 150 ohm bypassed with a 5uf cap. I left that in since I've read that a hybrid bias could be a cool thing but now I'm wondering if that is the cause of the early breakup. The weird thing I noticed when I was checking voltages is that the cathode pin on output tube one was 3.5volts and on the output tube two it was 38.7volts. I would think that they should be the same. That got me thinking that maybe that asymmetrical voltage between cathodes on tube 1 and 2 could be the cause of the early breakup. Both plates had the same voltage of 449DCV. All other voltages seemed correct. -43volts at the grids of the output tubes. Can anyone help me with what might be causing the early breakup? I'm thinking of taking out the cathode resistor and bypass cap on the output but I thought I should ask here first to see if there is something I missed. Also, is there any need for the 470k resistor the joins to the 220k mixing resistors just before the PI. It's not there in the AA864 circuit. Thanks in advance.
joseph
joseph
