low volume outpout
  • low volume outpout
    good day i have this amp. of mine it used to work just fine.but suddenly the output volume became so low.
    what is the problem?? what part of the amp is broke?
    Hi and welcome.
    What is the make and model?
      its a sony stereo mhc-dx5 amp
        Good luck with the problem being isolated to 'one part'.
        These 'mini hi fi's' are a real hoot to get apart.
        If both channels are low in volume, it may be a simple power supply issue, which would involve testing each of the power rails.
        The output ic is a STK402 brick. One per channel.
        The service manual can be found here:
        http://archivos.diagramas.mx/audio/H...0DX5J%20sm.pdf
          yes both of the channels volume is low
            Lets start simple.
            Do the headphones work?
            The headphone jack mutes power to the speakers. A bad jack could cause the problem.
            Have you tried other speakers?
            They could be blown.
              headphones volume is low too
              and no i didnt try other speakers
