Originally posted by Britt Rossman
View Post
Gibson GA-100 amp is a troublesome critter...
Okay guys, idk if the last post went cuz I'm not seeing it. Here is what I got:
I pulled 30R and 1n5408's off the recto, and no dice. Changed lead dress, as AC mains wiring to switch was crossing over the filter caps - nothing. Read voltages... B+ at OPT center tap = 465vDC - WOW that's hot! (It's starting to get late here, so I can't keep testing) When I whack it, it goes down by 15-20vDC.
OKAY, checked on Variac to get B+ at 440V, and checked bias:
Va1=440vDC, Ia1=28.6mA, Pa=12.6W
Va2=443vDC, Ia1=21.1mA, Pa=9.4W
So these tubes are 25% mismatched... While 22W is OKAY, I dont think that's how I wanna be getting it. Besides this, I think I'm gonna have to get higher voltage-rated caps if it is to be plugged straight in... Ugh.
Either way, the "ducking" issue is still here. Could it be the drastic mismatch? Never heard of that...
EDIT:: dropped in my matched tubes from my other 6L6 amp early in debugging this guy and somehow killed one tube guess it was time for that one... I do beat them up hard. Should I be replacing with new?
Originally posted by Britt Rossman View PostOkay guys, idk if the last post went cuz I'm not seeing it. Here is what I got:
Originally posted by Britt Rossman View PostOKAY, checked on Variac to get B+ at 440V, and checked bias:
Is this problem simply caused by the compressor? Does changing the position of the compressor switch have any effect? Try pulling V4 and V5 to ensure the compressor is disabled.
Originally posted by Britt Rossman View PostEDIT:: dropped in my matched tubes from my other 6L6 amp early in debugging this guy and somehow killed one tube guess it was time for that one... I do beat them up hard. Should I be replacing with new?Last edited by nickb; 01-30-2016, 03:11 PM.Experience is something you get, just after you really needed it.
Yea, didnt even think to isolate that. Come on, dude...Anywany, that did it... I must have shorted the compressor out in there somewhere. Frankly, not worth it to have that in there.
I put a 5V4 recto in there and I'm now gettin 455vDC B+ from mains of 121vAC I still think this is hot, but I really don't wanna have to buy more caps... I'm cheap!
If that's the safest route, however, I'm totally down.
Originally posted by Britt Rossman View PostYea, didnt even think to isolate that. Come on, dude...Anywany, that did it... I must have shorted the compressor out in there somewhere. Frankly, not worth it to have that in there.
The zener at $0.52 is the cheapest option 1N5352B-TP Micro Commercial Co | Discrete Semiconductor Products | DigiKey if you're buying some other stuff.Experience is something you get, just after you really needed it.
Well, I have some F&T 22uF caps on hand, and they're rated 500v... I think I'll just swap those out since inrush on startup is peaking at ~490V... that's a little much for those poor 450v-rated lytics... Even with 15v zener, I'd be seeing voltages ~25v higher than the rating.
The REAL problem is that the caps are rated for a standby arrangement that doesnt apply B+ to anything until it's thrown, YET this amp just ties the 6L6 grids together. FYI, that still produces sound when the volume is crank and the input is given some juice... It's crackly and fizzy, so I'm sure it's GREAT for those power tubes. Maybe I should rewire the standby to go from the first filter node-->switch-->choke instead of the arrangement now. That's the method recommended by Merlin Blancowe...
Originally posted by Britt Rossman View PostWell, I have some F&T 22uF caps on hand, and they're rated 500v... I think I'll just swap those out since inrush on startup is peaking at ~490V... that's a little much for those poor 450v-rated lytics... Even with 15v zener, I'd be seeing voltages ~25v higher than the rating.
The REAL problem is that the caps are rated for a standby arrangement that doesnt apply B+ to anything until it's thrown, YET this amp just ties the 6L6 grids together. FYI, that still produces sound when the volume is crank and the input is given some juice... It's crackly and fizzy, so I'm sure it's GREAT for those power tubes. Maybe I should rewire the standby to go from the first filter node-->switch-->choke instead of the arrangement now. That's the method recommended by Merlin Blancowe...Experience is something you get, just after you really needed it.
I rearranged the standby, but the results were fizzy and distorted ... weird. So I changed it back. Installed those higher rated caps at the first two nodes that are receiving high inrush voltages. Buttoned her up, new speaker installed and original (still functional) in a box.
I'm now satisfied beyond any doubt that I can return this and not see it for a long while. Cannot wait to get this thing off my bench and back to an appreciative customer! I'll post some pics soon as I can figure out how...
Originally posted by Britt Rossman View Post...I'll post some pics soon as I can figure out how...
