I live in a very humid area (SWFL), and I see a lot more failures from oxidized pots and switching jacks, etc than I did when I lived in New England. I use De Oxit D5 to clean pots and jacks, but I wonder if guys are using a second product to seal and protect after cleaning to lengthen the time these parts will work before oxidizing again. I have a little sprayer of De Oxit S5 sealer, but I'm not sure if it is the way to go for pots?
keeping cleaned pots quiet
Yes, same product, different name. "NOTE: (Name change in 2006: From CaiLube MCL to DeoxIT FaderLube, part numbers remain the same)".
CaiLube MCLOriginally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by TimmyP1955 View PostNot close at all. I've yet to find any material or finish that was not QD safe (unlike BrakeKleen).Attached FilesExperience is something you get, just after you really needed it.
Originally posted by Amish Mel View PostThis is a brand new amp, no way the pots should be dirty already, but I will try with some pot spray I have.
BTW, I see spraying pots as a measure of last resort to be used when no replacement is available.Experience is something you get, just after you really needed it.
