HV rails, yes, but of course that is the entire power amp.
C3 measures shorted but only one direction? If the cap was shorted, it would measure so both directions. But you already pulled the caps anyway. SHorted main filter caps are pretty unusual.
By the way, the diode test is nice in that it is a shorted, non-shorted sort of test, but when it gives you a shorted indication, then it is time to use resistance rather than diode test. The diode test will beep at zero ohms as well as at maybe 200 ohms, yet those two conditions are usually from far different things. SO it is a useful distinction.
On the far right, see D31,32? they are wired reverse bias across the output and rails. With a speaker load, then they are essentially across the supplies too. SO no power but loaded, do either of those diodes test short? Or no load and measure right on the parts.
When powering up, even on the bulb, always work with NO speaker load until the amp is stable and not making DC. In fact, if powering up on the bulb lights it bright WITH a load but not WITHOUT a load, that is a VERY valuable clue.
So: is C3 just shorted (whether itself or the circuit it is in) or does it measuer like a diode? If it does measure like a diode - "shorted" only one direction - that sounds more like something in the circuit is shorted putting a junction across the rail.
ANy time transistors blow up, ALWAYS check all the resistors associated with them.
Q10. You removed it and left it out? The amp won't work that way. You can leave out 12 and 13 for testing, but not 10. is that 47 ohm above Q10 open? How about the one under Q11?
You checked for EC shorts on the outputs? Good. Did you check for E-B shorts on them? If Q14 is shorted EC, then with a load, the base of one of the positive side outputs acts as a junction to ground, maybe what you are seeing. And BC shorts too, always check all three potential short paths on a transistor.
Were you checking transistors in circuit? remember all these drivers are wired directly to each other, so for example the EC of Q14 is parallel the BC of Q16. SO if you pull a shorted transistor, before putting something new in, go back and t=check the remaining transistors to make sure another bad one was not hiding under the short of the first one, so to speak.
