Hey guys,
Working on a Traynor YCV40 that had a blown Q1 LM7824 voltage regulator. I replaced the component, and then found that U2 has also blown. I replaced that as well, and then powered the unit up on a current limiter. First off, the Standby switch is functioning to the extent that it's switching the Red and Yellow LEDs, but not turning off the B+ voltage. I'm also not getting any negative voltage at U1 or U2.
The limiter bulb starts out dim, but as the power tubes warm up it gets bright. Brighter than it should. On my bias meter i'm seeing 25mA.
It appears to me like there's a bad diode affecting the negative voltage to U1 and U2, but the diodes all seem to test okay. In the past i've had them test out well but end up being the problem anyway. I've attached a link to the service manual. Is anything popping out at anyone? Thanks in advance for the help!
http://traynoramps.com/downloads/servman/sm_ycv40.pdf
