Re: Prior forum post http://music-electronics-forum.com/t12356/
Schematic: 2475-130_and_2275-130.pdf
One of our MusicMen, a 2275-130, had the tremolo stop working. I read the prior posts on here, and I referenced the one above that had great information. I verified that the oscillator is working and feeding the FET gate properly. Both + and - 16V supplies are fine. So I ordered a new FET, a J111. Replacing it and twisting the trim pot throughout its range still yielded no tremolo. I compared the specs of the original and the J111, and saw that the cutoff voltage is -5 to -10 volts for the 2N4091, and is -3 to -10 for the J111. So if I understand correctly, the gate should swing in the 0 to -3 volt range using the J111. I increased the 330K resistor (schematic shows it as 220K by the way) to 470K and was able to get the gate input to swing in the 0 to -3V range. Still no tremolo. I temporarily replaced the resistor with a substitution box and tried ranges from 0 to -10 volts, still no tremolo in any range. I verified that the resistors, intensity pot, and caps after the FET that feed the op amp were all good. So I pulled the FET and wiggled the intensity knob back and forth and induced a working tremolo. I believe that validates everything after the FET, so I am left confused on what to try next. I appreciate any insight or help.
