Hello all,
I am sure most of you will be used to people saying that have issues with this amp. I am no different, since my amp recently started cutting off at random after playing it for a while and after some digging found the usual suspects were to blame (R78/R79 overheated and were coming off the board). I swapped the resistors with 7W 470R ones, and replaced the diodes CR13/CR14, plus another resistor that had burned out (R97). I plugged the amp back on and it was playing fine then I switched the channel, and now I'm stuck on the drive channel... which, after some digging, I found it to be a symptom of the problem I thought had just fixed. I'm a bit stumped now, the only other information I can give is that both R78 and R79 give me a voltage measure of +33/-33 when it should be +16/-16. Any thoughts on what went wrong?
Thanks
P.S.: if you want to have a look at the schematics, look no further:
hotrod_deluxe.pdf
Thanks
hotrod_deluxe.pdf
