Hi all.
I'm no amp guru, but I have replaced electrolytics before. Everything will go swimmingly I'm sure (With the amp plugged in and and the power on, I'll bleed off the current through my finger while standing in the shallow end of the pool. That's the rule, right? Safety first.). No, seriously, I know all the precautions and will do the job safely.
Questions:
When I bought my most recent Sunn it had already been re-capped with a vintage type can. I plan to use individual caps instead. Should the caps be wired in series or parallel? I can't see inside the cap can to know. I looked at the schematic the other day, but I'm not real great with schems, so I wanted to confirm with you guys.
Also, the guy when he recapped the Sunn replaced all the electrolytic caps in the amp. Is it really necessary/desirable to replace the small non-power supply caps too?
Thanks. But don't go away. I will have some other questions once I get all the parts (the Traynor has other issues).
Questions:
