When I power on the amp there is a bump. And when I play guitar the sound is reduced and distorted, like a transistor fuzz.
I tested the power rails:
TP1 is 32VAC
TP2 is 32VAC
TP3 is 41VDC but there is also 93VAC!!
TP4 is -41VDC but no VAC
TP5 is 16VDC and there is 36VAC!!
TP6 is -16VDC but no VAC
I tried to change the electrolitic caps C71-C72 (4700) but same problem. I tested the diodes value and I think they are good (D53-D54-D55-D56-D57-D58). Even C75 and C76 are good.
I don't know what is the problem and what kind of test I can do.
TP1 is 32VAC
TP2 is 32VAC
