I have one of these that needs a new input jack. The owner has lost the jack inside the amp several times, most recently after I tightened it myself and then bumped his cord with my knee.
The schematic seems to show that it uses a switching jack that shorts tip to earth when not in use, and that it has a second switch pole which earths ring when in use and when not in use.
What I am missing?
I was planning to use a Switchcraft jack (have some on-hand) with a single switch to ground tip when not in use, and point-to-pointing the resistor and cap on the back of that.
Does anybody have a smarter repair for this? The factory jack seems to be a problem with these amps.
Thanks,
Wes
What I am missing?
Thanks,
Wes
