I'm really unclear about the DSP. This is an older stage 100 head. It doesn't say anything about a DSP.
fender stage 100 head loud input hum
Originally posted by sidman View PostI couldn't find a model number. All it says is model stage 100. There's no DSP listed.
There is no plus 5 volt power supply in your amp. So nevermind.
If you have checked all of the ICs for voltage on the input/outputs, then check the filter caps for the 16 volts power supplies. These are C65, C66, C67 and C68.Attached Files
Originally posted by 52 Bill View PostSorry, I should have known that your amp didn't have the DSP because of your question about the reverb tank.
