Need some advice please.
I just finished my 30watt jtm45 kit. Some problems I'm having are:
Channel 2 (both ch 2 inputs) work fine. Sounds great.
Now it gets confusing :-/
Channel 2 is fine if the channel 1, volume is on zero. If im playing through channel 2 and adjust channel 1's volume (greater than 0), channel 2 will not work. Also there is a noticeable hum when I adjust channel 1's volume (as well as channel two going silent).
Now more confusing: these symptoms seem to only be present when bass, treble and middle are not on zero. Seems most effected by treble tho.
Last problem: my presence pot is microphonic - it can be lightly heard amplified through the speaker.
In general terms, I can play through channel 2 with no problem....sounds great. I can adjust base, treble, mid and be fine....presence is consistently microphonic though.
When I adjust channel 1's volume (with treble, mid, bass greater than zero), channel 2 inputs do not work.
Some things I've done:
Changed out presence pot and 100nF cap
Changed out volume 1 pot and 250pF cap.
Soldered grounds again
Changed out preamp tubes
Ohm and wire checks, several times.
Rewired and soldered input jacks.
Nothing has helped.
Later today: I'm planning to take out the turret board to inspect underneath. It ohm checks fine though. I even veriy shorts to ground.
Any suggestions???
Nothing has helped.
Any suggestions???
