Hi all,
I have an Earth Amp BT-2000 Bass Traveler 45w on the bench. It has two burnt diodes in the bridge rectifier (a tech before me insulated the circuit board from the chassis with painters tape, it wore through and POP!). The remaining diodes have ICC 170 printed on them, but I'm having no luck finding a cross reference guide. I looked up the Peavey Pacer schematic (which is very close to the BT-2000) and it calls for 1A/200PIV diodes (1N4003). I measured the voltage on the PT's secondary: 54VAC.
Bottom line, is the 1N4003 diode a safe replacement for this? I appreciate the help!
Thanks
Thanks
