Anyone know offhand what the resistive side should be in a Fender style optocoupler when disconnected from the board? I have one that is slowly rising in value while on the meter.
Issue is '66 Pro Reverb AA165 with light side of opto flashing when switched on, but no Tremolo. And, with it switched off, the intensity pot lowers the channel 2 volume as it is turned up, as though the opto was stuck in conduct mode and partially grounding the signal. It was ticking, so I hit some solder joints, and now I have this, so I'm thinking it damaged the opto.
Can I get an Amen on this?
