Hi everyone, it's my first time posting here and also the first time trying to repair an amp, so please excuse me if my questions are trivial
Some days ago I was playing thru my VHT Special 6 combo and I noticed something strange in the sound: it appeared very low in volume, like it had a blanket on it, like it lost all its sparkle.
For this reason I compared it with a Special 6 head I have (both are non-ultra version and run the same type of tubes: 6v6gt and 12ax7) and the difference was clear! Comparing them on the same speaker the head was almost twice as loud as the combo!
It's clear something went bad in the combo.. Could it be because a friend of mine the day before used the combo for more than an hour at max volume (yes, at 10/10) in boost mode?
At first I thought of the tubes: they were not the problem because I switched them between the head and the combo and the difference was still the same (head almost twice the volume).
So I opened up the combo to search for some burned electrical component but everything seemed alright at first sight.
At home I had just a voltmeter so I checked just the bias resistors (the 470ohm and the 5K ohm ones) and they were fine.
I've read that the problem may be caused by a bad capacitor: for this reason I'm buying a capacitor tester and I'm going to test all capacitors and resistors in the circuit.
I know I'm being quite vague and it's not easy to help me out like this, but I have a question.
Can you think of something else (except capacitors and resistors) that could have caused the problem of the loss of volume?
Since it's my first time repairing an amp I would greatly benefit from knowing which are the most probable causes of the problem.
Thank you very much and sorry again for my inexperience
