My newly acquired little carnival tube amp sounds distorted and I need help trying to figure out why.
This is a 3 tube audio mono amp; 12AX7 6V6GT 6X5GT with original Toshiba tubes. 3 pots; Volume 1, Volume 2, on/off Tone.
I do not really notice the distortion when running a single tone signal, only when playing music full of different audio signals. Rock song intros do not sound too bad, but once the whole band kicks in, the distortion is there. I have tried this with different speakers and a different set of pre-amp and output tubes, still have distortion.
I have checked every resistor in the amp and they are all very close to spec.
I do not have the schematic and I think the voltages on the 12AX7 plates seem low.
All VDC readings to ground, no signal, all pots set to zero. All heaters were between 11.3 and 11.4 VDC. PT taps were 260 VAC. Below are my voltage readings
12AX7 pins
1: 94.7 V
2: -6 mV
3: .95 V
4: 11.39 V
5: 11.39 V
6: 79.4 V
7: .17 mV to 0 (keeps moving around)
8: -.23 mV
9: 11.4 V
6V6GT pins
1:
2: 11.3 V
3: 273 V
4: 245 V
5: 19 mV
6:
7: 11.3 V
8: 11.7 V
6X5GT pins
1:
2: 11.3 V
3:
4:
5:
6:
7: 11.3 V
8: 290 V
Attached is a picture of the chassis.
Thank you
12AX7 pins
1: 94.7 V
2: -6 mV
3: .95 V
4: 11.39 V
5: 11.39 V
6: 79.4 V
8: -.23 mV
9: 11.4 V
6V6GT pins
1:
2: 11.3 V
3: 273 V
4: 245 V
5: 19 mV
6:
7: 11.3 V
8: 11.7 V
6X5GT pins
1:
2: 11.3 V
3:
4:
5:
6:
7: 11.3 V
8: 290 V
Thank you
