Yes, that would seem to show a bad transistor.
The higher value caps are probably more for power supply filtering and decoupling. The ones that you really want to know about are the signal path coupling caps, which are typically smaller values.
What Enzo said is correct about swapping drain and source pins, I was more concerned about having the different pinouts of the two transistors mixing up the elements.
Originally posted by fastmerc
View Post
