While checking out the bias supply on this amp I found that the DC on the heaters of V1 V2 seems low.
The voltage from the -27 volt supply is low at -24.4 vs. -27 on the schematic. I'm measuring the heaters correctly this is giving me 5.85V DC per heater.
When I switch to the dirty channel the -DC bias voltage drops further, leaving me with only 5.55VDC for the heaters.
I know it's not hugely off, but I want to know if this is right before I close it up. Should I be concerned?
By the way, 121.1 VAC from the wall.
