Friends...
The local high school brought me a Roland D-Bass 210 amp. It is DOA. Before I get any further, I thought I might check in with you all to see if anyone has any experience with these amps. Is it worth me spending time to troubleshoot or is this a known problem child and we move on to something else?
The amp chassis was a bear to remove. On the bottom side of the chassis, the case had a hole and the wires ran through there. Typically, that is not a problem But Nooooooooooooooo... Roland uses a rubber plug with lots of goop and removing the chassis was a definite chore.
I can see a cage for the power supply and another for the power amp. Again, before I go any further, I thought I would ask for divine guidance. The amp also uses a speaker that has some type of Optical Sensor on the speaker which provides feedback to the preamp and power amp.
Finding a schematic is tricky... you need to become a member of some web site and then you can download a manual etc etc etc. I don't know if Roland would respond to a query for a schematic. I'll try.
Thanks, Tom
Thanks, Tom
