This unit, a wireless receiver would turn on but that was it......Upon inspection, I noticed that the Power was being dragged down.......Couldn't find anything that was obvious and after much prodding and poking, I decided to remove the voltage regulator and soldered a pin to where the output pin would be....Hooked up a current adjustable power supply and set the voltage for 10V......and hooked up the board.....I then turned up the current slowly while looking for an overheated IC chip.....I slowly kept increasing the current until there was close to 1 amp of draw ( I wouldn't chance going any higher than that)........voltage was down to probably 1V....The problem turned out to be a very small ceramic cap and not an IC chip like I had thought....it had a funny color to it once it was stressed.....As soon as I removed it, the short was gone....checked the cap.....sure enough...it was shorted......and that was the only part that was bad......The cap was on the power supply leg and every pin on all the chips showed a short to ground....and the power rail went all over the board.....It took awhile, but I managed to get it working....maybe this might help somebody out someday.......
Cheers
Cheers
