Hi guys and gals, new to the forum.
I have spent a few weeks searching as a guest and reading all the posts regarding the TDA723 IC's.
I have a decent background in tube amplifier circuits with some classroom training in the mix. I haven't spent much time applying that theory to SS amps, so the "extra" or unfamiliar components can often cause confusion.
I accepted an AVT-150H from a regular client as a favor. Initially the complaint was simply the IC's overheating and causing the amp to intermittently lose output.
I ordered the TDA7293V's from Mouser, and replaced them.
As you may guess, the replacements failed. VERY quickly, might I add!
I used Arctic Silver 5 which is highly conductive. I replaced the IC's again, this time using Arctic MX-4 electrically non-conductive/non-capacitive thermal paste.
This time, no explosion, but a loud noise from the speakers so I immediately ceased that operation.
I ordered a fresh pair of complete modules and of course, the same noise.
At this point, I have 4 more TDA7293's and the 2 unmolested modules with the original IC's considered dead.
My main question right now is how to test the IC's to see if they are, in deed, dead.
I have the ST Datasheet from September 2010.
Best guestimate, I aligned the IC as depicted in the pinout diagram and tested Pins 7 and 8. Both have continuity to ground, so I assume this can't be good as Pin 7 is +Vs. Of course, Pin 8 would be grounded to tab as denoted by the datasheet.
IS this the proper way to determine if the IC's are functional?
Should the IC's be dead, Can someone explain the safest process to reinstall the modules to prevent eating through more IC's?
I ALWAYS drain caps before repairing and amp, but apparently this may not be sufficient.
Thank you for your time and attention!
Allen Gordon
Allen Gordon
