Hello,
Nice little forum you guys got going here. This is my first post, but after perusing your site for a few days I think I am probably in good hands with my issue.
I played this amp for 5-6 years with no problems, then just recently the boost channel stopped working. It also had a real scratchy master volume pot, so I purchased some contact cleaner and a new 12AX7 and went to work, hoping this would take care of it.
I cleaned all the pots and all the jacks and installed the tube, but still no boost channel.
Here is what I know;
Old tube was a Telefunken ECC83 30170, new tube is a JJ T-12AX7-S, EEC83 S
Volume pot issue is fixed
Upon a good visual inspection of the viewable component side of the PCB's, everything appears good. No blown caps or burnt resistors. Nothing obviously fried.
When pressing the boost channel switch, nothing happens and LED for boost channel does not come on, and none of the knobs work
LED for footswitch (a Crate 2 pedal switch that worked before) does not come on for either distortion or chorus
Chorus appears to work
4x12 cab is good
The f/x pedal I use in the loop doesn't seem to make any difference in the sound
It also appears that someone may have hot-rodded this thing, there are two resistors wired onto the PCB near the input jack that don't look stock to me.
I have some electrical knowledge and skill. I am real good with cars, and can wire my house. I have also done some PCB soldering, and diagnostics down to the component level but only for a year or so.
I have never worked on an amp.
I did pick up some Marshall schematics for an 8280 from another site that I think I found linked here, approximately 5 of them, but really dont know much about this type of circuitry.
I do have a DVOM and soldering iron and all the necessary tools to repair it, except the know-how.
I like this amp, so any help would be much appreciated.
Thanks!
4x12 cab is good
Thanks!
