SVT 7 Pro Help.
  • SVT 7 Pro Help.
    Have a SVT 7 Pro that is turning off after about 5 seconds then back on and off again stuck in this cycle with no load connected.
    I found some dark spots on the 2A165 controller and replaced it and it didn't fix the problem. I'm going to try a 2A265 but still feel there is another problem causing the shut-down to occur. I've combed components and can't find any bad or shorted diodes and Mosfets with diode check. Can anyone give me a way to find out what is actually causing the reset and where to look for what may cause it ?
    KB
