I have one of these that I'm in the process of resurrecting. (It had a problem with the bias sensor power supply, which I've managed to fix).
I'm not sure whether it should be a 117VAC or 220-240V model fan. The primary side schematic shows the fan wired between mains-neutral and one of (can't tell which) the primary winding ends on the power transformer. (The amp is a 2008 model amp made in Vietnam). The fan won't run when plugged into the fan plug (on the top of the big chassis). At this stage I can't tell if the fan is working or not because I can't get any VAC reading across the fan plug leads (J15 and J16 on the terminal board), no matter which setting the polarity switch is on. The mains fuses are both intact.
http://bmamps.com/Schematics/ampeg/A..._Schematic.pdf
The power comes on at the wall with the power switch on in standby mode, and there is bias voltage on all the 6550 gird socket pins (I haven't biased up the 6550s yet or plugged them in, because I want to get the fan working first. (The bias voltage reading was present on all socket pin #5s with all the pre-amp tubes - including the 12AU7 drivers - plugged in). The pre-amp tube filaments all light up and there is a good heater voltage between the heater socket pins (6.6VAC without the 6550s plunged in).
Would the fan be something to do with the operation of the relay (K1?) in standby mode? Does the amp need to be in full on mode for the fan to work? Seems off that I don't have any AC voltage between J15 and J16 on the main terminal board. But then again, there's tell tale signs that someone else tried 'fixing' this amp before it arrived to me. There must be a connection between J15 and J16 at the terminal board - because I get a 2R reading between J15 and J16 without the fan plugged in. But would the fan lead terminal clip have been put back in the wrong place by a previous tech? Should it be a 240VAC fan hooked up between J14 and J16 (on the terminal board)? Or will I cook the fan if I try this (if the fan is actually 117VAC)?
