Hi. I have a Marshall VS100. Channel 1 (clean) works ok but sounds just a little wooly. Hardly noticeable and if you had a cheap budget amp that sounded like it you would be happy. channel 2 however whilst you can hear a little white noise when its turned right up, theres no sound through it, on OD 1 or 2. There is quite a draw on the -12V rail resistor R21 (42V one end and 26V the other end. This in comparison to -42V and -36V on the -ve resistor R20). Its not burning up but obviously running hotter than normal.
Im suspecting a dodgy op amp chip pulling on the rail but as theres several possibilities wondered if anyone had come across this one and could give me an educated guess which one to start with? The -ve rail is at -12V while the +ve is at 11.3v so that ties in with the big drop on R21.
And this despite the fact that the Marshall diagram shows the 12 volt regulators putting 15 volts out?? whats that about?
TIA
Andy
TIA
Andy
