I wanted to remove the front panel of my Bassman 135 this evening. Had trouble removing the two screws on the input jack side of the amp as the preamp tubes were in the way. Easy - release the 'tin' tube shields, pull the 3 12A?7 tubes and remove the two front panel screws on that side.
But on the other side, one of the 6L6GC tubes has to be removed to reach the front panel screws. But the 4 power tubes each have these spring loaded 'top-hat' hold downs that I can't seem to remove. If you look at the attached photo, there is a vertical spring on either side of the tube that is screwed down to the chassis at the tube base.
Unless I'm missing something, the two screws need to be removed, to remove the top hat, thus allowing me to pull the tube and reach the panel screws. OK, so turn the amp head upside down and the screw (bolt) on the outside is easily reached. But the other screw is behind the tube. The only way I could see this being removed (or installed) would be if the chassis was outside of the head cabinet. Just like this photo that my tech sent me when he installed the top hats.
It appears that I can NOT remove these hold downs while the chassis is in the head cab. Please tell me that I am clueless and that there is an easy way to remove these hold downs while the chassis is still in the cab. Otherwise I'm stuck - I can't take out the power amp tubes and I can't remove the front panel. That pretty much stops my cleaning effort.
I really hope my ignorance is easily over-ruled by experience. I hate to stop jobs before finishing them......
