Hi,
Can someone please help me out with the following issue:
Here is the story: in the beginning I thought that what I experienced was related to the power tubes. My amp went dead, and the first thing to do is probably to check the tubes. When I changed the two EL84 and the fuse, amp was working again. Then I find myself with 4 pairs of "non working" EL84 in less then a year of light amp use
Even for an Vox amp, "the tube eater" as people say it is too much. So I opened the amp to do some research, and found five resistors with different value then in the schematic. Here it is: http://www.blueguitar.org/new/schem/..._handwired.pdf
In my Vox the R24 and R32 measure 3,3kΩ (in the schematic 1,5kΩ), R21 and R33 are 470Ω (in the schematic 100Ω). I will add one more, with less dramatic difference: R28 should be 130Ω, in my amp the value is 148Ω.
For the end I'll just add that recently I had an opportunity to check those tubes I thought dead and found that all of them are still working.
My technical knowledge is limited so any kind of input will be welcome
Is it on purpose that those values are changed? Is it an erreur? If so what are the consequences? Should I change those values back to what I see in schematic? ...
Thank you all in advance for your help!
Hrvoje
Hrvoje
