Smoke coming from amp
  • Smoke coming from amp
    Howdy,
    I have a long thread concerning some amp squeal going in the "theory & design" subforum, and although I hope to close it out soon, I encountered something today which I figured I would start a different thread on. (the squeal thread can be found here http://music-electronics-forum.com/t41633/
    Having reassembled what is essentially a modified tweed bassman amp (I have some switchable plexi like gain mods), I was playing it today with the back panel off and the volume/gain maxed and after a few minutes noticed some smoke coming out of it. It looked to me like it was coming from somewhere near the output tubes, but it was not flowing constantly and was very light in color, so it was hard to tell. I shut the amp off, looked for any visible signs of damage but saw none. I fired it up again, played some more, and again started seeing intermittent smoke.
    After the second time, I tried to feel around for hot parts. My 5W 470 Ohm screen resistors as well as the 1/2W 1.5k grid stoppers were not hot at all. The base of the 5881 output tubes themselves were extremely hot, but I would not be able to say if they were abnormally hot. I have a string of 5 10V 5W zener diodes between the center tap and ground in order to lower the B+, and those were hot enough that I could not hold my finger on them. However, I did not think the smoke came from where the zeners were located, so this may or may not be a related issue.
    The 5881 output tubes are no longer closely matched, which "may" be a result of them having gotten damaged during my debugging phase of the thread referenced above. They idle about 5mA apart, and although this is probably not an extreme mismatch, my first instinct is to replace the tubes with a fresh pair an monitor the amp for more smoke. Before I do that and potentially destroy another pair of tubes, though, I'd love to get some thoughts on whether there are other things to check first.
    I have the tubes biased at around 35mA and 30mA, respectively. With a plate voltage of ~430V and a rating of 23W, that essentially equates to somewhere in the 56-65% range of max plate dissipation. The tubes are reissue Tung-Sol 5881s and are rated only for 400V, but I have read that with a tube rectifier, they can handle more. I checked the bias again before playing the amp the second time, and I monitored it while playing - any time I stopped playing the bias was back to where I set it, so it did not seem to drift off.
    I am a little bit concerned about the zeners getting very hot as I somehow shorted them all during my debugging phase and had to replace them (not sure what caused that to happen, but at around the same time my GZ34 rectifier tube started flashing, so I don't know if that caused the zeners to short or if the failed zeners damaged the rectifier, or if these are unrelated - I did also replace the rectifier tube). Anyway, my PT has a max current rating of 250mA, so even worst case the 10V zeners should in theory be dissipating 250mA * 10V = 2.5W which is half of their 5W rating. Is there any situation where more current than this could be flowing through the zeners and CT?
    Anyway, does anyone have any experience with their amps smoking? Can a power tube itself ever smoke if it going bad , or is it usually a component such as a resistor, PT, choke, etc.? Any thoughts on what I should do first - replace the output tubes and hope that is the issue, or something else? I assume there is too much current flowing somewhere, but what, where and how do I test for that? My plate and bias voltages seem fine, but since the bias is checked when the amp is idle, I don't know that everything is fine when I am actually playing.
    They don't smoke from going bad, but if they are running hot, either from a failure or from improper biasing, any labels or things like that stuck to them can smoke. Some companies put matching labels on the tubes.
    5ma? I'd be happy if they were that close when new. This isn't rocket surgery.
      I had an amp smoke once, I thought, "Wow, I AM good!" Took the amp in and the guy said it was a tube, nothing else harmed. My amp was starting to sound funny and cutting out when it happened.
        Thanks guys. The tubes did have labels on them, so I removed them and the sticky residue just in case that was causing the smoke. There was no sign of charring of the label, though, so who knows.
        Anyway, I played the amp some more today at full volume. I checked the bias before I started, and measured the plates at ~430V and idle current at 31mA and 35mA (~60-65% of max plate dissipation). I played for several minutes, then checked the bias again and noticed that the bias had shifted significantly. One tube went to 56mA and the other to 70mA! Plate voltages dropped to 420V or so, so not a huge drop. After a couple of minutes of not playing, the bias went back down to normal.
        I was wondering if something was going on with the zeners, so I switched to high plate voltage mode (I have switch that brings the zeners in or out of the circuit between CT and ground for low and high plate voltage modes). Plate voltages were ~485V and the idle current 29mA and 33mA (60-68% of max plate dissipation). I played for a while, and checked the bias again. the V4 tube went up to 50mA or so whereas V5 did not seem to shift much at all. Again, the bias corrected itself after the tube was left on but without me playing the guitar.
        I then swapped the two power tube positions to see if the problem was related to one tube only. I got similar results with V4 in that its bias shifted upwards quite a bit after playing a few minutes as full volume.
        I assume this tube position specific (i.e. V4) bias shift would suggest it's not really a bad tube issue, but I am not certain since when I was playing in the lower plate voltage mode I saw a shift on both tubes. I'll have to play around with it some more tomorrow and maybe swap in a new set of tubes just to rule that out.
        Any thoughts on what could cause the bias to shift like this?
          Post the schematic.
            Sorry for the delayed response - work got kind of busy!
            Here is my layout - it is a bit messy, but please let me know if something is not clear. There are several switchable mods in the preamp section to go between stock 5F6-A and something more like a Marshall 1987. In the power section, you will see a switch for a lower voltage mode which adds 5 zener diodes between the PT CT and ground. When these zeners are in circuit, I get very close to the voltages listed in the original 5F6-A schematic. Because of the zener switch, and because I also wanted an option to use SS or tube rectification when I am in high voltage mode, I have a more complex bias circuit than usual as it involves 3 mini 50k pots. I have been able to bias 5881's, 6L6GC's and EL34's, so it seems to work. I also have a switch to allow me to use 470 Ohm or 1k screen resistors (I believe I read that the EL34 tubes should have 1k or more).
            http://i270.photobucket.com/albums/j...gal%20size.jpg
            Here is the original Tweed Bassman layout (5F6-A) which my amp is based on:
            http://acruhl.freeshell.org/mga/sche...s/bassman1.jpg
            I have not seen any more smoke lately, but I am having some issues. First of all, it appears that at least a couple of my zener diodes are no longer working (perhaps what caused the smoke originally). I assume this is due to too much current having passed through them and them having overheated, but I don't know that for sure. They are 5W 10V zeners, so that would suggest that more than 0.5A (500mA) went through? Perhaps since there is little ventilation, there was less current needed for failure. Anyway, when I play the amp maxed out for a few minutes, I notice that the idle bias current of at least one tube (V4) is drifting upwards. I checked the coupling caps from the PI, and they do not appear to be leaking. When using the 470 Ohm screen resistors (same as as the tweed 5F6-A), I am seeing a ~0.5V higher voltage on the screens than on the plates. However, this is when the amp is idling. Could this be the reason too much current is flowing, or does it become insignificant when you're actually playing (or does it actually get more significant)? I get this same result with two different pairs of 5881 tubes. If I switch to the 1k screen resistors, I don't seem to get the same bias drift, and the screen voltages with the 1k resistors are ~0.5V lower than the plates. I am not sure if I played maxed out for more than a few minutes if the problem would arise even with the 1k's, but I have not tried that yet.
            If you look at the tweed bassman layout, you will see 432V at the reservoir caps and 430V after the choke (screen supply). I am getting only a 0.5V difference there, which in turn presumably leads to my screen voltages being too high with the 470 Ohm screen resistors. Is the 0.5V drop across my choke smaller than what would typically be expected? My choke is a Mercury Magnetics FC-2.84 and is intended for the tweed bassman amp.
            I'd love to hear anyone's thoughts!
            Last edited by sleipnir; 04-13-2016, 11:57 PM. Reason: fixed link to 5f6-a layout, attachment did not work
