Picked up a Studio 22 combo (this is not the 22+ version, it does not have the 5 band EQ). It has low output until you jump the FX loop with a patch cable.
I cleaned all the pots and jacks with Deoxit with special attention to the FX loop jacks. Was hoping that would fix the patch cable issue but it did not. What is the typical reason for this issue and remedy? Are new jacks the only cure, or is it a poor connection issue that can be mechanically corrected, or something else?
This amp also had its ground pin removed at the power cord plug and has a broken off volume pot, both of which I will be replacing.
Thank you.
Thank you.
