I had to replace three main boards on a set of JCM2000s due to the 'creeping copper' problem. Two went just fine (didn't even need my soldering iron) but the third one is having an odd problem. The one sides biases up fine (using the little trim pots and 'three pins') but the other keeps reading 0v. Changed tubes, no difference. I pulled it apart again and re-flowed all the solder joints on the little bias bias board (with real solder, not that ROHSs stuff
). Measurements at the jumper pins seemed to make sense (~10k across the pins to the two 22k pots in parallel, turning the pots changes the resistance at pins 2 and 6, zero ohms from pins 3,4,5 to their respective test point pins). I put it back together, still the same. Recall that this is a brand new main board fresh from Milton Keynes.
Probing further, I noticed something odd -- the bias board jumper wires are mirror-imaged (pin 1 goes to pin 7, 2, goes to 6, etc.) Since the connector wiring is symmetrical, it still "works," but the pots need to turn the opposite direction and the left pot controls the right tubes and vice-versa. This caused a bit of confusion when I was testing at pin 5 on the tube sockets.![Mad](https://music-electronics-forum.com/core/images/smilies/mad.png)
As many of you know, powered testing is an adventure because of that %$#%$ output jack board. Insulated foam board to the rescue.
More testing:
- The 1 ohm cathode resistors measure 1 ohm, there is continuity between the high side of these resistors and the external test pins and the cold side and ground.
- Turning the trimmers changes the voltage at the 220k grid resistors.
- The voltage at the (L-R swapped) pin 5 changes on one side, but stays fixed at -45v or so on the "0 volt cathode resistor" side.
- Continuity from the 220k Rs to individual 5k1 grid stoppers, and from the stoppers to the socket pin 5s.
- With caps discharged, all pin 5s measure about 300k to ground, about what you would expect.
Any suggestions?
![Thumbs Up](https://music-electronics-forum.com/core/images/smilies/icon_tup.gif)
More testing:
Any suggestions?
