Hi There,
Looking for some advice on the speaker voltages I should be seeing on this amp when at full chat. I have the amp connected to my trusty 300w GLX dim bulb current limiter, and when I open up the master volume once it hits 7 on the dial the bulb starts to emit light. Not the full 300w of nitesun light when there's a short but I'd say between 25 and 50% brightness.
All I have is the schematics courtesy of DrGonz78 (thanks again chap). These don't show any test voltages other than the HT supply to the 12AT7.
Have observed the clean channel on my crusty old scope and once the bulb starts to glow the clean 400Hz wave I'm injecting into the amp front end is clipped to the point where the wave is almost trapezoidal at full beans (Observed at the dummy load).
User is complaining that the amp noise cuts out at 7 on the MV dial but using an 8ohm DL I dont see this on my scope. This could be the Dim Bulb absorbing some of the load. I dont really have the option of running the speaker at full beans as I live in a house joined to 3 others.
Any help greatly appreciated.
