I really think you should fix the voltage you noticed as top priority. That should not be happening. Something is causing the leakage and it can only get worse. Using yourself as a current meter is probably not the smartest thing to do...
The very first thing to check is for wanted very low DC resistance from the earth pin of your power plug to the chassis.
